Activity Forums VEGAS Pro codec to get mov files to play
  • codec to get mov files to play
    Posted by James Redmond on March 15, 2011 at 6:48 pm
    Hi!
    I had another client send me a mov file that will not play in Vegas Pro 10c (nor SpeedEdit, nor Sorenson Squeeze 6.5). I had install QuickTime 7.6.8 and tried install 7.5 with the same results. Quicktime will not play it.
    G-spot can not tell me any information about these files.
    So I’m stuck with how to get this file to work in Vegas.
    Any idea what codec I would need?
    Thanks, James
    James Redmond
    Dynamic Videos, Inc.
    Rogers, AR USA
    James Redmond replied 15 years, 6 months ago 2 Members · 2 Replies
  • Mike Kujbida
    March 15, 2011 at 7:01 pm
    James, you definitely need to ask your client where the file originally came from.
    Since nothing you have will read it, my guess is that it may be from a P2 camera in which case you’ll need Raylight from DV Film to be able to read it in Vegas.
    The drawback is that it’s a $200 plugin 🙁
    Another guess is that they might be DVCPROHD or DVCPRO50 files.
    DV Film to the rescue again with Decoder
    The good news is that’s only $45 🙂
    Demo versions of both products are on the website.
    If you or your client has access to someone with FCP, it can read these files natively and spit out a ProRes file which Vegas can read.
    Premiere can read P2 files as well.
    I’m not sure about DVCPROHD or DVCPRO50 files.
  • James Redmond
    March 15, 2011 at 7:34 pm
    Mike, it was recorded with a Sony X1U and then he converted to mov. Luckily he sent the tape and now I’m trying to find a way to play it. Thanks, James
    James Redmond
    Rogers, AR USA
