Activity › Forums › Apple Final Cut Pro Legacy › Codec quirks making exports difficult
  • Codec quirks making exports difficult
    Posted by David Ghast on August 9, 2008 at 7:16 pm
    Ive been in the process of converting my PRORES HQ footage over into a non proprietary format, and it was suggested that i use the animation codec to do so, but i noticed that the result was always different than my source and found that where my source had no gamma or alpha values listed, animation had given it the values of gamma source, and alpha straight. I found that visually the uncompressed 8-bit was identical, yet i dont have a large enough screen to tell if i took a resolution hit in doing so. The bitrate of uncompressed was 20mb/s, and the bitrate of animation was 30/mbs, as compared to my source footage of 8mb/s. Should i go with what looks visually identical or will the difference of 10mb/s produce a noticable hit in resolution?
    Rafael Amador replied 18 years, 1 month ago 2 Members · 1 Reply
  • Rafael Amador
    August 10, 2008 at 2:18 am
    You will go from 10b Compressed YCbCr (Prores HQ) to 8b Unc RGB.(Animation).
    Why don’t you have a look to Sheer (www.bitjazz.com)?
    Gives you 8/10b Unc YCbCr/RGB. Half the size of the Apple Unc or Animation.
    Always with Alpha channel available and cross-platform.
    Rafael
    http://www.nagavideo.com
