Activity Forums Adobe After Effects Codec question
  • Codec question
    Posted by David Cohen on April 27, 2006 at 6:13 pm
    Hello cow folk,
    I am working on a project with an AVID editor who requires 1:1 compression. Typically, i usually work with Animation codec exports, or 2:1 merridian exports.
    I am running AE 6, and i atempted to export a 720×486 29.97 comp with the Meridien Uncommpresed codec.
    I then recieved a render error – “error commpressing file – no such volume.
    Is there soemthing different in the output module settings between Merridien 2:1 and Uncommpressed?
    Any help would be appreciated.
    -Dave-
    Harryjf replied 20 years, 2 months ago 2 Members · 1 Reply
  • Harryjf
    April 27, 2006 at 6:23 pm
    Try this:
    In the Render Queue, go to the Output Module for your render. Click on “Format Options” under Video Output.This brings up the Compression Settings with another “Options…” window. Click that.
    Set it to “RGB Levels”, not “ITU-R 601” .
    Sometimes that setting screws things up.
    Harry J Frank
    graymachine.com
    New After Effects tutorials!
