Activity Forums Apple Final Cut Pro Legacy codec question
  • Posted by Justin Heaney on April 10, 2005 at 2:22 am
    Hi All.
    I just captured a commercial off my showreel via mini dv internal firewire on FCP 4.5.
    Because it was coming off mini dv, I made a DV Pal sequence 100% quality.
    I decided to do a Blackmagic 10bit sequence as well.
    The Blackmagic 10bit sequence render looked flawless, yet the DV pal sequence render looked just OK….with poorer chroma sampling etc…
    My question is this.
    Because this clip was on a DV tape, how did I manage to “unlock” stunning 10bit brilliance from what was on the tape???? Is DV not 5:1 to tape compressed??
    Cheers
    Justin Heaney
    Graeme Nattress replied 21 years, 5 months ago 2 Members · 3 Replies
  • Graeme Nattress
    April 10, 2005 at 11:48 am
    All you’ve avoided is the render back to the DV codec. You’ve done two different things:
    a) DV -> Firewire -> FCP (DV gets uncompressed, Effect added, DV recompressed) ! -> Firewire -> DV Tape
    b) DV -> SDI (DV gets uncompressed) -> FCP (Effect added) ! -> SDI (DV gets compressed) -> DV Tape.
    Exactly the same things happen, but in different orders. From what you’re describing, you’re viewing the footage from a) & b) workflows at the ! point, and hence, as you can see in a) you’ve just compressed back to DV, but in b) you’re still uncompressed, and hence it looks better. Nothing magic going on here.
    Now, if in workflow b) you subsititute a Digital Betacam deck for the DV tape, you avoid the DV compression and decimation back to 8bits, and will preserve 99.9% of the uncompressed quality you see at that point. If you’re mastering back to DV tape, there is no point capturing the DV uncompressed, as things may look better at the ! but as soon as you get back to tape, you’ve completed the decompression and recompression, lost your digital generation and there’s nothing you can do to avoid that.
    Also, I should point out that FCP does not do the DV codec justice onscreen in the canvas, whereas it does display the uncompressed codecs with very much higher quality, so there’s a bit of an unlevel playing field there too, for viewing at the !.
    Graeme
    http://www.nattress.com – Film Effects for FCP
  • Justin Heaney
    April 11, 2005 at 1:12 am
    Thanks Graeme.
    Both Codecs viewed on a PAL moniter.
    Just to confirm. Am I correct in assuming that DV material once captured to a 10bit uncompressed sequence is basically “unzipped” to reveal its highest quality? Then zipped (or compressed) again when going to DV tape. some sort of loss reversal???????
    Cheers
    Justin
  • Graeme Nattress
    April 11, 2005 at 1:58 am
    Ziping is lossless compression, so it’s not quite an appropriate analogy. But that’s reasonably close, remembering that DV is quite lossy.
    Graeme
