Activity Forums Adobe Premiere Pro codec problem on CS5
  • codec problem on CS5
    Posted by Sterling Youngman on January 15, 2011 at 7:00 pm
    I have some old footage that requires the LSI MJPEG Codec, from Morgan Multimedia. It has worked perfectly on CS3 and CS4, but I upgraded to CS5 yesterday. You guessed it, CS5 does not recognize the footage. Is there a trick to getting it to understand the files’ codec?
    Cheers,
    Sterling
    Sterling Youngman replied 15 years, 8 months ago 2 Members · 4 Replies
  • Steve Brame
    January 15, 2011 at 8:39 pm
    Windows or Mac?
    Just a thought…if Windows, you were using a 32 bit version of the codec with CS3 and CS4. Being that CS5 is a 64-bit program, the 32 bit codec might not be compatible.
    Steve Brame
    creative illusions Productions
  • Sterling Youngman
    January 15, 2011 at 9:19 pm
    I’m running Windows 7, and I suspect that your thought on it being a 32bit codec is probably correctly identifying the problem.
    Maybe, I can convert everything to Cineform, which will work in CS5.
    -Sterling
  • Steve Brame
    January 16, 2011 at 12:24 am
    Looks like they don’t have a 64 bit version available, so you definitely will have to transcode. Can’t go wrong with Cineform!
    Steve Brame
  • Sterling Youngman
    January 16, 2011 at 12:31 am
    I emailed the developer to see if there would be a new version available, but I’m not holding my breath.
    Now I have to ask myself if I should use Instant HD to up-res the footage. It was shot on 35mm, so I could redo the transfer, but that would cost some bucks that I am not interested in letting go of.
    -Sterling
