Activity › Forums › Adobe Premiere Pro › codec problem (mostly audio)
  • codec problem (mostly audio)
    Posted by Anderson Guering on April 14, 2014 at 7:41 am
    I’ve captured some footage with a little software called Bandicam, which captures my PC screen with incredible performance thanks to it’s Nvidia’s CUDA support. They just took their website down and no support is available at the moment.
    Now I’m trying to edit this footage in Premiere, but Premiere is having hard time interpreting its audio. The video looks OK, but the audio is completely incomprehensible. Like it is in slow down or something.
    I’m not sure if it’s a codec problem. If tell Bandicam to not use CUDA it will let me edit the footage just fine, but there will be a huge drop in performance and especially in file size. The thing is, with CUDA settings, I’ll have a definitive solution if I wanna capture hours of footage, so I really don’t wanna to give up on this for another codec.
    The footage runs fine on VLC, Media Player and all. The problem occurs just with Adobe softwares – Premiere/AE/Media Encoder – they all will have this same problem.
    I’ve ran the file on mediainfo to try determine what’s wrong with the audio, but I’m not an expert. It looks like a regular MPEG codec for me.
    In a last resort I would just try to convert the footage to another format I know Adobe will get it right. But I already have 5 hours of captured material and It would save me tons of time if I can just work on them directly on Premiere.
    The mediainfo’s info is as follows:
    Format : AVI
    Format/Info : Audio Video Interleave
    File size : 591 MiB
    Duration : 5mn 19s
    Overall bit rate mode : Variable
    Overall bit rate : 15.5 Mbps
    Writing application : BandiAviMuxer 1.0
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : H264
    Duration : 5mn 19s
    Bit rate mode : Variable
    Bit rate : 15.3 Mbps
    Maximum bit rate : 40.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 60.000 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.123
    Stream size : 581 MiB (98%)
    Audio
    Format : MPEG Audio
    Format version : Version 1
    Format profile : Layer 2
    Codec ID : 50
    Duration : 5mn 19s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 9.74 MiB (2%)
    Alignment : Aligned on interleaves
    Interleave, duration : 24 ms (1.44 video frame)
    Interleave, preload duration : 48 ms
    Chris Tompkins replied 12 years, 5 months ago 2 Members · 1 Reply
  • Chris Tompkins
    April 14, 2014 at 2:52 pm
    Try dropping the raw file(s) into AME – export audio only to 48k .wav file.
    Bring new audio file into Pr and merge with the video.
    Chris
