Activity › Forums › Apple Final Cut Pro Legacy › codec not found you maybe using….
  • codec not found you maybe using….
    Posted by Jim Holden on November 6, 2010 at 11:05 am
    new to final cut, my apologues
    codec not found you maybe using a compression type with the corresponding hardware card
    i took from sd card and saved to desktop
    also when playing the file through vlc the audio keeps cutting out
    codec reads MSADPCM
    Jim Holden replied 15 years, 10 months ago 2 Members · 5 Replies
  • Jerry Hofmann
    November 6, 2010 at 4:09 pm
    Which Camera shot it the footage? It likely needs transcoding. Might try MPEG Streamclip. Free download, just google it.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    DVD:https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Jim Holden
    November 7, 2010 at 12:19 pm
    thanks i’m encoding it now
    it was a cheap camcorder, my dad’s friend’s, a toshiba
  • Jim Holden
    November 8, 2010 at 1:58 pm
    still nothing. the clip can only be played through vlc, hmm
  • Jerry Hofmann
    November 8, 2010 at 2:01 pm
    MIght try transcoding the file with MPEG Streamclip. Just google it, it’s free.
    Jerry
    Current DVD:
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Jim Holden
    November 9, 2010 at 9:27 am
    yeah i downloaded it and tried exporting in different formats with no result. the clip won’t even play in streamclip. no option to convert either
