Activity Forums Apple Final Cut Pro Legacy Codec not found. You may be using a compression type without the corresponding hardware card.
  • Codec not found. You may be using a compression type without the corresponding hardware card.
    Posted by Marco Aguilar on September 10, 2012 at 12:22 am
    “Codec not found. You may be using a compression type without the corresponding hardware card. ”
    Not 100% sure what that message means. It happens when I try to render something or export something. Stops both processes.. My timelines settings are:
    1920×1080
    Aspect Ratio HDTV 1080i 16×9
    Pixel Aspect Ratio Square
    23.98
    Compressor Apple Pro Res HQ
    Where do I start poking around?
    Shane Ross replied 14 years ago 2 Members · 1 Reply
  • Shane Ross
    September 10, 2012 at 2:12 am
    Do you have any pictures in your sequence? If so, make sure they are RGB, and not CMYK.
    Shane
    Little Frog Post
