Activity › Forums › Apple Final Cut Pro Legacy › Codec not found. You may be using a compression type… Apple Final Cut Pro Legacy Codec not found. You may be using a compression type… Chung Kim replied 6 years, 6 months ago 11 Members · 31 Replies Chung Kim March 20, 2020 at 9:14 pm I got a same error. You should check Sequence Settings> Video Processing> make sure that you select “Render in 8-bit YUV” instead of Render 10-bit… CK Page 4 of 4 ← 1 … 3 4 Reply to this Discussion! Login or Sign Up Public All Members My Connections Only Me PublicAll MembersMy ConnectionsOnly Me Public All Members My Connections Only Me Reply to this Discussion! Login or Sign Up
