Activity › Forums › Apple Final Cut Pro Legacy › Codec Not Found – Render Error
  • Codec Not Found – Render Error
    Posted by Davidbrim on July 8, 2007 at 7:32 am
    Just upgraded to Final Cut Studio 2.
    Opened a project in FCP6 I have been working on recently in FCP5. It updated the project as a newer version.
    Made a few changes to a sequence. Then tried to render sequence, but got the following error message:
    “Codec not found. You may be using a compression type without the corresponding hardware card.”
    I am working in HD 1080i50, however there is also some footage imported from a low res .mov in the sequence along side the HD footage.
    I do not know what settings have been changed to get this error message – I rendered the sequence fine in FCP5.
    What is going wrong?
    Russell Lasson replied 19 years, 2 months ago 2 Members · 2 Replies
  • Davidbrim
    July 8, 2007 at 11:11 am
    I have now figured out that there are some graphic scenes in my sequence that have been imported from a .AVI movie.
    Are there any codecs missing from the new FCP6? Because this sequence worked fine on my FCP5 version.
    Thanks.
  • Russell Lasson
    July 9, 2007 at 4:51 pm
    Do you have the flip4mac plug in installed on the FCP6 system?
    -Russ
