Activity Forums Apple Final Cut Pro Legacy Codec Not Found message
  • Codec Not Found message
    Posted by Marco Aguilar on May 23, 2011 at 5:43 pm
    I am attempting to export a self contained quicktime file of a 90 min feature film for a friend of mine. The frame rate is 23.98. Pixel Aspect Ratio is 1280×1080. The Quicktime Video settings for some odd reason are 1080p30 which I find odd because the sequence settings are 23.98. I keep getting two error messages. One is OUT OF SPACE which is impossible because I have over a TeraByte of space. Than it is followed by this message. CODEC NOT FOUND. YOU MAY BE USING A COMPRESSION TYPE WITHOUT THE CORRESPONDING HARDWARE CARD. Any suggestions? Thanks.
    Sam Cole replied 15 years, 4 months ago 3 Members · 2 Replies
  • Shane Ross
    May 23, 2011 at 6:02 pm
    Have any stills in the timeline? are they in the CMYK Color Space rather than RGB? That’s what is up when I get that message. And, any of these stills over 4000 pixels?
    Shane
  • Sam Cole
    May 24, 2011 at 4:00 am
    FCP will show those odd error messages when it runs out of memory.
    The work around is to close FCP and then restart and do your export immediately.
    I don’t know why it can’t just say “out of memory” rather than “codec error” or “out of disc space” or even worse “general error”.
    I wonder what all the new workarounds are going to be with the “X factor”
    Sam Cole
    On line Mastering Facility
    FCP, Avid, Adobe
    Sydney, Australia
