Activity › Forums › Apple Final Cut Pro Legacy › Codec not Found. HDV?
  • Codec not Found. HDV?
    Posted by Rory Hinds on March 21, 2006 at 12:18 pm
    Hi there
    I’m working on a HDV conform and grade from a XML file which opens fine on my Powerbook but I can get it to open on my G5 system as it keeps coming up with “Codec not found. You may be using a compression type without the corresponding hardware card.”
    Any ideas on how to get this running on my G5?
    I shouldn’t need a Hardware Card to work with HDV.
    Many thanks
    Rory
    FCPHD 5.0.4, Quicktime 7.0.4
    Rory Hinds
    http://www.whatismine.com
    David Roth weiss replied 20 years, 6 months ago 3 Members · 2 Replies
  • Peter Mcauley
    March 21, 2006 at 3:52 pm
    Hey Rory how’s it going. I had this the other day and it turned out to be a bug on my AJA KOna 2 driver. Are you using firewire or do you have an i/o card? Any plans on visiting Toronto soon, are you going top NAB?
    Peter McAuley
    Axyz Edit
    Toronto
    G5 dual 2.0
    4 gigs ram
    10.4.3
    FCP 5.03
    QT 7.03
    Kona 2 v1.1.4 with K Box
    4 X 250 gig external F800 Lacie firewire drive
    2 X 23″ Apple cinema display
  • David Roth weiss
    March 21, 2006 at 3:53 pm
    One of the recent software upgrades (FCP or QT) blew away the HDV codec for some users. It happened to few folks I know, but not on my own system. You’ll need to get the codec somewhere and install it.
    DRW
