“Codec not found” – FINAL CUT PRO 5.1.4
Hello. When I try to open a new sequence in FINAL CUT PRO 5.1.4, I get the following message:
“Codec not found. You may be using a compression type without the corresponding hardware card.”
I am running a 2.2ghz MacBook Pro with 2GB memory and GeForce 8600MGT. Dose anyone have any ideas what the message means?
Thank-you all.
Cheers.
