Activity Forums Apple Final Cut Pro Legacy Codec Not Found Error Message
  • Codec Not Found Error Message
    Posted by Michael Barnes on June 22, 2012 at 3:52 pm
    I am editing a commercial on FCP 7. I had a clip that was round-tripped to motion (a .motn file extension) that the client did not like. I laid a matte over the motion clip and added text and a JPG logo for the restaurant. Now when I try and render, I get the following ERROR MESSAGE: Codec not found. You may be using a compression type without the corresponding hardware card.
    I changed from unlimited RT to safe RT. Still got the error message. I’ve had this error message before and I fixed it by changing under Audio/Video Settings/Sequence Presets/Video Processing selection TO RENDER IN 8-BIT YUV. Didn’t work this time.
    Anyone have any suggestions? Is the .motn file screwing up the rendering? Feedback greatly appreciated.
    Mike
    Tony Brittan replied 14 years, 3 months ago 3 Members · 2 Replies
  • Shane Ross
    June 22, 2012 at 5:05 pm
    The JPG….open it in Photoshop and change the color space from CMYK to RGB.
    Shane
    Little Frog Post
  • Tony Brittan
    June 23, 2012 at 11:03 am
    Like Shane said. And for god measure, make sure the .jpg is 72 dpi and then save it as a .png.
    Posted from iPad, please excuse typos!
