Activity Forums Apple Final Cut Pro Legacy Codec not found (??????)
  • Codec not found (??????)
    Posted by Jack Bibbo on July 26, 2009 at 9:57 pm
    Upon rendering in a seq, which is NTSC 720×486 ProREs (HQ)
    I receive the error
    :Codec not found. You may be using a compression type without corresponding hardware card.:
    Using Kona LH / 8 core.
    One work around that I have done is to export the clip as ProRES (HQ) the bring it back in. But you can understand what a hassles that will be.
    Most clips in show have already been converted so that is a non issue.
    But how can it not see a codec that is already there when I want to render something?
    thanks in advance.
    jack
    Jack Bibbo replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
