Activity Forums Apple Final Cut Pro Legacy codec not found
  • codec not found
    Posted by Paolo Mugnaini on July 25, 2007 at 1:31 am
    Hello,
    I had some issues and I had to re-install my operating system.
    Before I had the issue I was working on a project…it had different formats on it, I exported it for DVD Studio, I saved it. Today I went to open the project again and it told me this “codec not found. you may be using a compression type without the corresponding hardware card” I kind of get what it means….but I don’t.
    Now I can’t even open the HD QT files I had. I re-installed QT but no luck.
    Can someone please help?
    thanks
    Paolom
    Paolo Mugnaini replied 19 years, 1 month ago 2 Members · 4 Replies
  • Neil Ryan
    July 25, 2007 at 5:36 am
    do you have any extra hardware?
    aja or BlackMagic cards, etc?
    Neil Ryan
    Post Production
    The Pod Multimedia
    http://www.the-pod.com.au
  • Neil Ryan
    July 25, 2007 at 5:37 am
  • Paolo Mugnaini
    July 25, 2007 at 12:31 pm
    Hello,
    No I have a pci firewire card but that’s it (i used FCP and QT since I had it and …no issues)…..external HDs but no such card…..
    I am not sure if it’s a QT issue. But if it is why now….?
    thanks
  • Paolo Mugnaini
    July 25, 2007 at 10:33 pm
    Has anyone had major problems re QT 7.2? Not playing HD and 10 bit files? showing a white screen? and on FCP this message “codec not found. you may be using a compression type without the corresponding hardware card” ” out of memory” even if you have 4.5gb?
    this issue is causing me fits and costing me $$. can someone please help?
    thanks
    P
