Activity Forums Apple Final Cut Pro Legacy Codec not found
  • Codec not found
    Posted by Randolph Harrison on April 25, 2009 at 12:31 am
    Hi All,
    I recently had to reformat my hard drive, and instead of installing FCP 5.1.4 which I had been using… I upgraded to 6.0.5. Software update this my system was totally up to date.
    When I try to open the FCP projects that were done in 5.1.4, I get the window to upgrade my project. I select “yes”, but after the project is read, I get the error:
    “Codec not found. You may be using a compression type without the corresponding hardware card.”
    I tried changing different settings. I even tried to open a new project but still get the same message.
    Thank you for your help.
    Randolph
    SYSTEM:
    G5 Quad 2.5
    8 gb Ram
    2 x 23″ Cinema Displays
    OSX 10.4.11
    FCP 6.0.5
    2 x Burley Enclosures
    10 x Seagate 500 gb
    Sonnet Tempo SATA E4P Host Card
    Original projects were captured DVC ProHD 1080i60
    Sequence preset was DVC ProHD 24p
    Footage was reverse telecined
    Rafael Amador replied 17 years, 4 months ago 2 Members · 1 Reply
