Activity › Forums › Avid Media Composer › Codec issues when transfering from PC to MAC
Posted by Austin Ray on November 7, 2005 at 12:01 pmHi!
I
Oliver Busch replied 20 years, 11 months ago 3 Members · 6 Replies -
R. Hewitt
November 7, 2005 at 12:28 pmSounds like you need to export in Quicktime. It should be on your Avid already, if not it is available at low cost from Apple.
Oliver Busch
November 7, 2005 at 2:39 pmHello there,
You can download the free avid software (means: no Avid hardware required) codecs from:
https://www.avid.com/onlineSupport/supportcontent.asp?browse=go&productID=0&contentID=3555
On Mac OSX, only the Meridien codecs are supported (no ABVB, no NuVista, no DNxHD)Also, you get the codecs when you install Avid’s FreeDV. Here the Meridien and Avid DV codecs are installed.
A (more elegant?) way to get the stuff into AE could be the commercial AE import plugin from Automatic Duck:
https://www.automaticduck.com/products/piae/Hope this helps, Oliver
Austin Ray
November 7, 2005 at 2:52 pmAny method to use no codec at all? No compression what so ever? I haven
Oliver Busch
November 7, 2005 at 3:28 pmhi again,
maybe you could export the timeline as an image sequence which will work fine in AE.
don’t know what image formats are supported on current versions of MC, though.example (oooooold mac version):
https://avidfaq.anglepark.com/Export.htmlOliver
Oliver Busch
November 7, 2005 at 3:31 pmI’m referring to the “PICT sequence” feature in the dialog box shown in the link above (the article itself shows export to QuickTime).
Oliver
