Activity Forums Apple Final Cut Pro Legacy Codec issues
  • Posted by Daniel Goldstein on August 10, 2010 at 6:54 pm
    Hi, here’s my predicament.
    I did a video for a client and I exported it as a quicktime from Final Cut Pro. I put the files on dvd and sent them to the client. It’s 5 months later and they are complaining that they just tried the video and it the codec doesn’t work with windows.
    Here’s the problem…
    I no longer have the original files, computer problems, hard drive problems… they’re gone.
    Is there any solution for myself and my client?
    Can they watch the apple codec files on their computer with something like https://www.dvfilmstore.com/raylight-decoder.html ?
    Or can I take the files that they have on cd and convert them to play for windows? If so, how?
    Daniel.
    Daniel Goldstein replied 16 years, 1 month ago 4 Members · 10 Replies
  • 10 Replies
  • Mike Throck
    August 10, 2010 at 7:59 pm
    Get the video back, export them from something like Quicktime, Compressor, ect. in the DV/NTSC codec.
    They should have no problem viewing this codec on a PC.
  • Jeremy Garchow
    August 10, 2010 at 9:02 pm
    [Daniel Goldstein] “I did a video for a client and I exported it as a quicktime from Final Cut Pro. “
    What codec and frame rate?
  • Daniel Goldstein
    August 10, 2010 at 11:31 pm
    Can you please give me step by step instructions on how to change the format in Compressor. I can’t seem to figure it out.
  • Mike Throck
    August 10, 2010 at 11:43 pm
    1. Open Compressor
    2. Click the “Add File” button in the upper left, or just drag you file into the project
    3. In the settings tab, click in the quick search field and type “ntsc” then drag the DV NTSC preset onto your file above.
    4. Click the destinations tab and pick somewhere to export the file to by dragging it onto the word “source” next to your file. You can also create a new destination by clicking the “+” symbol in the upper right.
    5. Click submit.
  • Daniel Goldstein
    August 10, 2010 at 11:50 pm
    Thank you, I’m trying it now and after it completes, I’ll let you know if it worked.
  • Mike Throck
    August 11, 2010 at 12:39 am
    good luck.
  • Rafael Amador
    August 11, 2010 at 12:42 am
    Yes, why don’t you start by telling us what kind of codec did you used?
    The solution may be easier than converting any thing.
    rafael
    http://www.nagavideo.com
  • Mike Throck
    August 11, 2010 at 12:50 am
    Any “apple codec” is going to give a PC problems.
    No?
  • Jeremy Garchow
    August 11, 2010 at 12:54 am
    Not really.
    Original codec, please.
  • Daniel Goldstein
    August 11, 2010 at 1:05 am
    The coding reads:
    H.264, AAC, Timecode, Text
