Activity Forums Adobe After Effects Codec help: FCP to AE on PC
  • Codec help: FCP to AE on PC
    Posted by Whitlock Dunbar on August 7, 2007 at 1:36 am
    As I experiment more & more with HDR and the 32 bit workspace, what is the best codec to use to retain the highest image quality in going from Final Cut 6 to AE 7 & 8 on a PC? Is there a way yet to utilize the 10-bit uncompressed codec in AE on the PC?
    Brendan Coots replied 19 years ago 3 Members · 2 Replies
  • Wes Plate
    August 7, 2007 at 3:36 am
    You can’t use a codec on Windows that doesn’t exist on Windows.
    — Wes Plate
    Automatic Duck
  • Brendan Coots
    August 7, 2007 at 5:32 am
    Blackmagic 10-bit would work nicely, as would Sheer Codec. Try to stay in 10-bit, which will prevent loss throughout the various stages.
    As was mentioned, you should definitely look into Automatic Duck AE Import. It allows you to pull your entire FCP edit into After Effects, reconstructing all your edits, fades etc. and references the original source media like FCP so you don’t have to render out.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
