Activity Forums Apple Final Cut Pro Legacy codec for capturing HD on older computer
  • codec for capturing HD on older computer
    Posted by Joan Perlman on April 21, 2010 at 6:49 pm
    I’m unable to edit my HDV footage in FCP 5 (using an iMac G5 OSX4 with 1.25 gb memory, 1.8 ghz processor). Should I re-digitize my tapes using a low-res SD codec so I can complete editing and when done, up-res with a HD codec? Ideas on which SD codec to use are appreciated — standard DV-NTSC, or “DV to Offline RT NTSC (Photo Jpeg)”, or something else. Thank you!
    Shane Ross replied 16 years, 4 months ago 3 Members · 3 Replies
  • Don Greening
    April 21, 2010 at 8:25 pm
    On your older machine running FCP 5 my recommendation would be to use the NTSC DVCPRO 50 codec. I think it’s the best compromise between quality and file size. My .02
    – Don
  • Joan Perlman
    April 21, 2010 at 9:17 pm
    Don,
    Thank you for your response. I don’t have exactly that codec on my list but do have this one: DV50 NTSC 48 khz. Would this work as well?
    (DVCPRO is Pal only and there’s no “50” with it).
    Thanks again,
    Joan
  • Shane Ross
    April 21, 2010 at 10:47 pm
    You can’t capture HDV as DV50 (also known as DVCPRO 50) unless you had a capture card. HDV and DV are the only formats you can capture this as via firewire. And you have to tell the camera/deck to do the output as DV.
    Shane
