Activity › Forums › Adobe After Effects › codec error
codec error
Posted by Daveyg on January 26, 2006 at 5:36 pmI have a probelm with my mpeg 2 AE codec. Everytime I export out of ae an mpeg premier cant recognize it. I have a file that I made and other people cant open it up on their cpu. Any thought?
daveyg
Daveyg replied 20 years, 7 months ago 3 Members · 11 Replies -
Steve Roberts
January 26, 2006 at 5:55 pmNot everyone can read MPEG-2. The codec is usually used for DVD creation only, at the stage just before the burn. Then there are broadcast applications, and so on … but it’s meant to be used at the end of the process, for delivery, in certain situations.
Why are you rendering to MPEG-2 and what do you plan to do with the file that you render out of AE?
Daveyg
January 26, 2006 at 6:00 pmhow do i render an mpeg. its for an animated background that loops. lower quality. Am i missing somehting?
daveyg
Daveyg
January 26, 2006 at 6:09 pmi get an error now that says mismatch seetings output module and transcode settings. this is when i uncheck the audion settings. thanks
daveyg
Steve Roberts
January 26, 2006 at 6:56 pmDo not render to MPEG for a background. The background will be used in another project, so you should use a higher-quality codec such as Animation or Photo-JPEG to avoid the quality loss when you composite the background later on. Render at full resolution and high quality.
Roland R. kahlenberg
January 26, 2006 at 7:19 pmHi Dave, I believe that you emailed me a number of months back. I tried responding but each time my email to you bounced back. I’ve since cleared my emails. So, if you’re still interested in the FOC copy of a broadcastGEMs product, then please send me another email.
With regards to your current issues with MPEG2 renders from AE, it is important that you let us know the composition settings, its duration, audio/no audio, render and output module settings and the actual MPEG2 settings. Sounds like a lot but without those bits of info, it’s going to be difficult to know what’s the issue.
HTH
RoRK
broadcastGEMs
customizable animated backdrops with Adobe After Effects project files -
Daveyg
January 27, 2006 at 1:55 amI sent another email. you could also try me at stoochy1@gmail.com thanks so much for the help. Im out of the office right now, but when i go back I will give you the specs. Thanks
daveyg
Daveyg
January 27, 2006 at 2:09 pmif I am using mpeg, i dont need quality, is mpeg2 the right codec to use?
daveyg
Daveyg
January 27, 2006 at 2:17 pmi rendered out again using mpeg2 no audio, under format options i used the main concept mpeg quality 5.
I try to import into premier and it says unsupported audio rate.
BUT, when I take an avi into premiere and exprt as an mpeg I can use it anywhere fine. THIS CONFUSES ME.
daveyg
Daveyg
January 27, 2006 at 2:25 pmOK I figured it out. I want to render mpeg 1 out of AE not Mpeg 2. How do I do that? Premiere has mpeg 1 codec. Thats the difference. Should I keep exporting out of ae as an avi file then convert to mpeg 1, but then what do I do about when I have 70 files to export at once. I cant sit there and do each individual sequence in premiere.
daveyg
Steve Roberts
January 27, 2006 at 3:36 pmCanopus Procoder or Sorenson Squeeze can be useful at times like this, giving you access to a lot of codecs and allowing you to batch process the files.
I use Compressor and Squeeze on the Mac for this sort of thing.
