Activity › Forums › Compression Techniques › Codec Error
  • Posted by Pete on September 3, 2006 at 10:14 pm
    Hey guys i just got a clip from a potential client, and is some basic ovies that they want me to tweak, do some animations etx… but when i open is white, obvious codec missing, but never heard of this one; wheni open in quicktime (the file is an AVI) under format it says
    720×480, millions, 16-bit integer (Little Endian), Stereo, 48.000 khz
    what is ithis, thanks.
    Charles Simonson replied 20 years ago 2 Members · 1 Reply
  • Charles Simonson
    September 4, 2006 at 8:56 am
    Most likely, it is an 8bit YUV uncompressed movie in either YUY2 or UYVY format. The only mac application that I know of to support this is Compression Master (as of 4.0.1 due to my requests). You could use CM to convert it to another format that you can work with, or you can get the client to provide you with an RGB or v210 (10bit) AVI.
