Activity › Forums › Adobe After Effects › codec Error
  • codec Error
    Posted by Pete on September 3, 2006 at 10:25 pm
    Hey guys, sorry for posting this message here if it doesn’t belong here, i just didn’t know where elso to post it…
    i just got a clip from a potential client, and is some basic ovies that they want me to tweak, do some animations etx… but when i open is white, obvious codec missing, but never heard of this one; wheni open in quicktime (the file is an AVI) under format it says
    720×480, millions, 16-bit integer (Little Endian), Stereo, 48.000 khz
    what is ithis, thanks.
    Steve Roberts replied 20 years ago 3 Members · 4 Replies
  • Roland R. kahlenberg
    September 4, 2006 at 3:35 am
    [Pete] “16-bit integer (Little Endian), Stereo, 48.000 khz”
    These pieces of info relate to the audio encoding. There is nothing mentioned about the video CODEC. Import the file into AE. In the Project Window, select the file and press one of the modifier keys, CTRL, ALT, CTRL. Sorry but I can’t recall the exact key combo. Once you’ve hit the jackpot, you’ll get some info on the four-character (not the foul word) code for the CODEC. That should give you a better idea.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    Customizable animated backdrops with Adobe After Effects project files
  • Pete
    September 4, 2006 at 4:48 am
    Thanks RoRk, didn’t even bother to look in AE, i was only doing info fom quicktime, but that worked, unfortunately, is in IV50 which is an intel thing, now avail on Mac, thought i’d share, thanks again.
    September 4, 2006 at 2:03 pm
    There are Intel legacy CODECs are cross platform. But ver 5.0 isn’t one of those. The Indeo CODECs are now supported by Ligos. And Indeo CODECs were developed for CD-ROM and HD delivery of postage-sized videos. Definitely not ideal for broadcast work.
    Cheers
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files
  • Steve Roberts
    September 4, 2006 at 3:19 pm
    Indeo codecs were used in the mid-to-late 1990s for the purposes Roland mentioned. Definitely obsolete and not for broadcast.
