Activity › Forums › Apple Final Cut Pro Legacy › Codec degradation over generations or renders?
Posted by Matt Campbell on March 18, 2010 at 6:25 pmDo camera codecs such as DVCPro50 and DVCProHD and even non-camera codecs like ProRes degrade after multiple renders in my timeline? Or do they only degrade after being output to tape and/or output to a digital file and then are brought back into FCP for continued use?
OS 10.5.5, Mac Pro 2 x 3 ghz quad-core intel xenon, 9 gb ram, with BM Intensity Pro card
Matt Campbell replied 16 years, 6 months ago 2 Members · 5 Replies -
Matt Campbell
March 18, 2010 at 7:05 pmI read about ProRes in the white papers and being able to hold to multiple outputs but just wasn’t sure about renders. Thanks for the clarification.
Rafael Amador
March 19, 2010 at 1:36 amHi Mat,
Rendering is always degrading.
Whenever you drop footage in a FC sequence, the footage is converted to full uncompress 444.
The last step of the rendering is the re-compression of that uncompressed image to the codec of the time-line. Here, unless you export to an Uncompress 444 codec, you will always have a lose.
Even if you export to 10b Unc, there is degradation.
Rafael -
Matt Campbell
March 19, 2010 at 1:27 pmHmmm. I didn’t know that. Thanks. So if I’m editing footage from our HVX 200 in a DVCProHD timeline, would it be best to transcode my masters on export to either ProRes or even 10-bit uncompressed files upon completion, to help minimize further gen loss from the DVCPro HD codec?
I don’t work with tape. We’re completely digital, since most of our material is for presentation videos, web and corporate video. Hardly any broadcast work at all. We farm that out to the big dogs! I simply archive my digital masters to our servers, which gets backed up to LTO tape.
Rafael Amador
March 19, 2010 at 3:45 pmHi Matt,
Whatever the footage you work with and the workflow you fallow, a rule of thumb is to avoid re-compression.
Unless you have to deliver in DVCProHD, there are advantages in rendering to a 10b codec.
but you also need to set “Rendering in high precision” .
This setting will improve the render quality and will work even if you render to an 8b codec.
rafael -
Matt Campbell
March 19, 2010 at 6:03 pmgreat. thx for the advice. I keep forgetting about that tab.
