Activity › Forums › Apple Final Cut Pro Legacy › codec and deformed images in fcp 7
  • codec and deformed images in fcp 7
    Posted by Seyi Adebanjo on January 1, 2014 at 10:40 am
    good day all
    having problems with fcp 7. im running 10.6.8 on a quad-core intel xeon tower. the files are on an external drive.
    when i play the 60 minute video on the timeline, sections give me deformed images/video that flickers green/blue with vertical lines at times. it will play the same distorted image in different places on the timeline. also get codec error at times.
    have un-installed fcp 7. taken it to the genius bar and had the graphics card replaced twice now in the past month. hasnt rectified the issue.
    the files play fine on a laptop with the external drive.
    they ruled out the fire wire connection being the issue. any ideas what the hardware or software issue could be?
    thank you
    thanks
    africa is the future!
    Steve Eisen replied 12 years, 8 months ago 3 Members · 3 Replies
  • Nick Meyers
    January 2, 2014 at 4:15 am
    what is the format / codec of your media?
    what settings are your timeline?
    nick
  • Seyi Adebanjo
    January 2, 2014 at 6:10 am
    hi nick
    sequence settings are
    frame size hdtv 1080i (16:9)
    pixel aspect ratio square
    editing timebase 23.98
    compressor apple proress 422
    48khz, 16 bit
    format hdv/codec hdv2 and apple proress 422
  • Steve Eisen
    January 3, 2014 at 3:59 am
    I’m guessing you are mixing codes on the same timeline. Hopefully you are not mixing frame rates (29.97 and 23.98)
    Prores is 1920×1080 and HDV is 1440×1920.
    The correct way to edit would be convert the HDV footage to Prores before editing.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
