Activity Forums Apple Final Cut Pro cmd E -ProRes export stucks at “preparing media for share”
  • cmd E -ProRes export stucks at “preparing media for share”
    Posted by Clermond Ferrand on May 22, 2018 at 8:12 pm
    Everything was fine until for weeks until today when I wanted to export a ProRes master from my project.
    A window popped up “preparing media for share” and FCPX stuck with the famous beachball.
    My mp4 compressor preset exports fine.
    I deleted the share settings and added a new one.
    I deleted the prefs of FCPX (alt cmd)
    I deleted PRAM when booting also I excecuted safe boot
    I still get stuck in the “preparing media for share”
    I attach my Pegasus to the MacBookPro and export the same project. I don’t see that window on my MacBookPro. It works fine except a notification about missing effects, generators or titles. I have no idea which one is missing but the video file looks okay..
    I found a work-around while typing: adding share destination as ProRes setting from Compressor.
    I am still curious what was happening?
    Jeremy Garchow replied 8 years, 3 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    May 22, 2018 at 10:33 pm
    I’d get this tool and have a look at all the effects with this tool:
    https://www.spherico.com/filmtools/X-Files/X-FXHandler/
    It will allow you to see, with a bird’s eye view, all the templates that are in that Project (after exporting an XML).
    It may point to missing effects (returns a value of “False” in the left column).
    Jeremy
  • Clermond Ferrand
    May 23, 2018 at 6:44 am
    thanks Jeremy for this hint. I know this great tool from Andreas Kiel and I checked this before. All effects are true. There is also no problem when exporting with my compressor presets. Missing effects should be affected there also.
  • Jeremy Garchow
    May 23, 2018 at 12:10 pm
    Do you have any slow motion clips with optical flow?
    Another thing to do is to make a brand new Project and copy/paste the program in to it. That may shake loose any weirdness.
