Activity Forums Adobe After Effects Cloud effect…yes I know its another one.
  • Cloud effect…yes I know its another one.
    Posted by Gnwanya on March 13, 2007 at 5:39 pm
    Hi all
    Before anyone has a go at me for posting a repetitive question, i understand that this effect has been covered numerous times before. I have gone through various versions, But i am continously struggling.
    I am trying to create the static clouds in the sky effect using Trapcode particular. But im always going wrong, whether its an emmiter issue or a particle issue, something always goes wrong. Please can someone give me a step by step guide to creating this effect on a 720×576 pal resolution. I would like to suggest the clouds seem endless in every direction.I have followed the tutorials on trapcodes site. But i would appreciate more advice.
    Thanks for your time.
    Gus
    Gnwanya replied 19 years, 6 months ago 2 Members · 4 Replies
  • Gnwanya
    March 13, 2007 at 6:06 pm
    Hi Dave
    If you meant the earlier “Animated clouds” post by dups303, then i was already one step ahead. 🙂 Unfortunately i’m still not having much luck there, as it really isnt step by step. Thank you for your imput. Trust me its really appreciated.
    Cheers
    G
  • Victor Nash
    March 13, 2007 at 7:11 pm
    here are some settings to mess with. This is just me messin around.. be sure to play around with colour over life .. light blues whites
    etc.. Plus let the particles build up for a second or two.. then orbit away.. Of course this is just me throwing something together.. feel free to alter to your needs..
    EMITTER
    particles/sec: 2000
    particle type: sphere
    Emitter X: 4000
    Emitter Y: 50
    Emitter Z: 4000
    PARTICLE
    Life/Sec: 2
    Life Random: 50%
    particle type: smokelet
    Smokelet Feather: 60%
    Size Random: 50%
    Opacity: 50
    Opacity Random: 50%
    Set Colour: Over Life (play with light blues and white gradients, not too extreme)
    PHYSICS
    Air
    Wind X: 300 (Play with your own direction, I just plopped this value in here 🙂
    Turbulance Field
    Scale: 4
    Move with Wind: 100
    Visibility
    Near Start Fade: 20
    Near Vanish:10
  • Victor Nash
    March 13, 2007 at 7:24 pm
    if you want still clouds, just animate physics time factor from 1 to 0 around 1 second into the animation and the turn the winds to 0
  • Gnwanya
    March 13, 2007 at 9:06 pm
    Hi thetaxidriver
    I know these were just settings you sent. But just to let you know, as a results i was able to track and understand what each parameter was doing and why. And in doing so was able make alterations as you suggested on the fly. Going forward its giving me a far better understand of particulars than i expected.
    Thanks very very much for your input. Great!
    G
