Activity › Forums › Maxon Cinema 4D › clothilde and vertex maps
  • clothilde and vertex maps
    Posted by Sketchbook on November 19, 2007 at 1:05 am
    hi all,
    i have an object that is setup with clothilde, and i am having a bugger of a time trying to get certain areas to stay put while others stretch and move.
    i have painted many a vertex map and placed them in every field within the forces “tag” tab but nothing seams to work as desired.
    if you are trying to get the fabric to stretch in certain areas and not in others, what do you recommend as far as setting up the vertex map, and after that, which field do you place the map into to create the desired effect?
    thanks!
    Brian Jones replied 18 years, 10 months ago 2 Members · 1 Reply
  • Brian Jones
    November 20, 2007 at 4:02 am
    It depends on what you are trying to get the cloth to do and what the scene is like. Try using the Belt tag perhaps and use your map on the Influence.
