Activity Forums Maxon Cinema 4D Cloth with moving belt tag object
  • Cloth with moving belt tag object
    Posted by David Wiffen on February 8, 2010 at 3:18 pm
    Hi Everyone,
    Bit of background to my setup…
    I have a scene with a falling olympic medal. The gold medal connects to a small linked chain, and this chain connects to a long fabric neck strap.
    I’ve set this up so the medal and chain are modynamic and the strap is cloth. I’ve then done some xpresso stuff to attach the final link of the chain to the cloth. This is done using a belt tag on a proxy that is linked to the chains cloner object using xpresso.
    This all works perfectly, the medal falls and pulls the cloth and chain about dynamically. No keyframes required.
    So on to the problem…
    As the medal falls, the belted object and cloth very slightly detach from each other and you can see the yellow belt lines extend away from their origin. As the medal hits the floor they catch up again and rejoin. I need them to be perfect butted up to each other.
    Is there a way to make cloth and a belted object always stay together whatever the animation?
    I’ve tried hover and influence, and different cloth settings but nothing seems to help.
    Many thanks in advance.
    David Wiffen replied 16 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
