Activity Forums Maxon Cinema 4D Cloth simulation showing holes
  • Cloth simulation showing holes
    Posted by David Cabestany on March 17, 2015 at 5:10 pm
    I have this cloth simulation,
    c4d cloth sim
    I finally got the cloth to behave the way I need it, but there’s a few holes punching through, I tried turning on self repulsion and self collision separately but they completely mess up the rest of the animation.
    Can anyone suggest a good method to fix this small holes?
    Thanks in advance,
    D.
    David Cabestany replied 11 years, 5 months ago 2 Members · 4 Replies
  • Brian Jones
    March 17, 2015 at 5:18 pm
    doesn’t look like holes, it looks like the cloth is penetrating whatever the cloth is laying on as it spreads out. Is that maybe true?
  • David Cabestany
    March 17, 2015 at 6:37 pm
    Yes, I think that’s the case.
    I have a cube below with a cloth collider tag. How can I avoid the cloth intersecting with? The whole point of it being a collider is for the cloth to rest on top of it.
    Best,
    D.
  • Brian Jones
    March 17, 2015 at 7:22 pm
    in the cloth tag’s Expert tab you can try increasing the Sub Sampling value – this will slow things down somewhat but can help if cloth is penetrating between frames because it’s moving so fast and/or you can try increasing the Point EPS (essentially the collision checking distance)
  • David Cabestany
    March 17, 2015 at 9:23 pm
    That helped, thanks.
    I’m not very well versed on cloth, so I struggle a lot to make the object move exactly the way I need it. Tons of little tweakings to get it look exactly how I need it.
    Best,
    D.
