Activity Forums Maxon Cinema 4D Cloth Parachute..
  • Cloth Parachute..
    Posted by Mjl Creative on April 17, 2007 at 1:29 pm
    I’m having a lot of trouble trying to create a simple parachute using the Cloth tags. I have tried creating the chute and ropes seperately, then attaching them using belts.. but when the simulation is run the chute breaks away from the rope belts.
    I have also tried to make a single poly object with the chute and ropes inside it. This resulted in the same thing happening with the chute breaking away.
    If anyone can suggest a method to create a parachute it would be very helpful. Even if your only able to point me in the direction of a tutorial or scene example it would be great, as i’ve had no luck when googling it.
    mjL
    Mjl Creative replied 19 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
