Activity › Forums › Adobe After Effects › Cloth changing. Is it possible with AE ?
Posted by Arsen Beglarian on November 4, 2011 at 5:34 amHi i want to make an effect of the cloth changing like in this video. Please someone tell me is it possible with AE if yes how?
Thank you very much in advance!Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Gary Cruz replied 14 years, 6 months ago 5 Members · 6 Replies -
Roland R. kahlenberg
November 4, 2011 at 8:49 amI haven’t done this myself but I’ve seen a video where FreeFormPro and Twixtor were used to create a similar effect. Of course lots of tracking and rotoscoping are involved. I can see FreeFormPro being used to unfurl parts of the clothes and Twixtor to tweak the speed/motion between frames although in this instance, the effect seems very quick and I’m doubtful if Twixtor was used.
Hopefully others can chime in. This is a good ‘mindfreak’ ad.
Cheers
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
Tudor “ted” jelescu
November 4, 2011 at 8:52 amYou can do the post production in After Effects, but the hardest part will be in the way you shoot the actors. If you want movement like in the clip you posted, then a motion control rig may come in very handy.
For the morphing of the clothes, FreeForm Pro can come in very handy, as it does 3d displacement and distortion and it responds to AE Lights.Tudor “Ted” Jelescu
Senior VFX Artist -
Arsen Beglarian
November 4, 2011 at 10:37 amThank you all! I will try if a can make it. Damn roto is always fun 🙂
Thank you very much! -
Chris Bobotis
November 4, 2011 at 10:05 pmRoland, Tudor, thanks for chiming in. A small correction. It was FreeForm Pro + Revision FX re:Flex prodcut that was used for the clip you are referring to. See:
Incredible Morphing using FreeForm + Re:Flex
Cheers,
Chris
mettle.com -
Gary Cruz
February 5, 2012 at 8:19 pmReminds me of this:
https://www.youtube.com/watch?v=vpdnTSJXtVA&feature=BFa&list=PLC09C157AF8C42CAC&lf=mh_lolzI would love to see a tutorial on how to use FreeForm (if available on mac) on how to do the Fructis morphs! That’s the best I have seen!
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
