Activity › Forums › Maxon Cinema 4D › Cloth animation 300 frames max
  • Cloth animation 300 frames max
    Posted by Olly Bea on October 29, 2008 at 10:28 am
    Hey
    I am playing around with the cloth tag in Cinema 4d and I have an animation that requires that cloth to ‘flap’ around for 750 frames, but it seems that when the animation gets to 300 frames, it just suspends all movement and stays stuck on the 300th frame.
    Why is this?
    Any ideas?
    Olly
    Olly Bea replied 17 years, 11 months ago 2 Members · 2 Replies
  • Brian Jones
    October 29, 2008 at 12:53 pm
    Cloth can turn on and off at the frames you want but by default it’s set to all the frames of the timeline and that is set when you first apply the cloth tag. So it sounds like you applied the tag when your timeline was set to 300 and you later extended it to 750. Whether that’s the case or not, go to Cloth Tag/Tag and uncheck Auto and set the Start and Stop points where you want.
  • Olly Bea
    October 29, 2008 at 2:29 pm
    works a treat, thanks a lot
