Activity › Forums › Maxon Cinema 4D › cloth animating
  • cloth animating
    Posted by Gon Perdigao on January 26, 2009 at 9:29 pm
    i there i want to creat a cloth that is suported by 3 cubes(one in the top and the other two in the sides), and i want to animate the cloth fallin down.
    So i made a plane and selected the points were i wanted to be the cubes, and click set in the fiz points, but now the cloth dont move, even if i put inside a null.
    How can i solve this?
    Brian Jones replied 17 years, 8 months ago 3 Members · 4 Replies
  • Brian Jones
    January 27, 2009 at 2:04 am
    Fixing the points isn’t what you need, you want to use the Belt tag which you can turn on and off (animate the Influence parameter). Quick Example
  • Gon Perdigao
    January 27, 2009 at 12:30 pm
    Sorry i explain my self wrong, what i want is this that the cubes hold the plane, cause in your example the cloth dont hold in the cubes.
    Is there a way to do this?
    Thanks a lot for your quick anwser
  • Randy Johnson
    January 27, 2009 at 1:07 pm
    I think you want to fix three sides of the plane (do not enable dresser just click “set”) Then put your rubber setting higher (like 75%)
    Or if you want three side to stay and stretch the other fix one side and use a belt tag to a cube that has been key framed already.
    /Randy
  • Brian Jones
    January 27, 2009 at 3:17 pm
    Belts are still likely the way to go. The boxes are in a different place but the cloth is held in place by the belt tags until frame 60 (if I recall correctly) where the Influence of the belt changes from 100% to 0, only then does the cloth slide off the boxes.
