Activity Forums Maxon Cinema 4D Cloth and belt points
  • Cloth and belt points
    Posted by Vince Becquiot on January 25, 2006 at 2:17 am
    This is a flag and pole problem… I am having problems with moving both the flag and the pole as a group on an axis.
    The belt points don’t follow the move.
    Any suggestions ?
    Vince
    Mike Moon replied 15 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Base80
    January 25, 2006 at 2:11 pm
    what version of C4D?
    Belting has changed a bit in 9.5
  • Base80
    January 25, 2006 at 3:04 pm
    I noticed while trying that the belting object and the cloth should not intersect. When the two objects are separated by a tiny distance it al works well.
  • Base80
    January 25, 2006 at 4:05 pm
  • Vince Becquiot
    January 25, 2006 at 6:21 pm
    That was it ! They were intersecting… hmm strange indeed.
    Great tutorial by the way. The hairy flag is a great one 😉
    Thanks a million,
    Vince
  • Mike Moon
    July 14, 2011 at 7:38 pm
    I love that tutorial but I can’t make it work on c4d r12? Can anyone tell me how to do this on r12? I’m trying to make a kite and have the tail animate with the kite and I can’t make it work. Thank you
  • Brian Jones
    July 14, 2011 at 9:24 pm
    in12 a Cloth tag and Belt tag both go on the tail. Select the points of the tail that are supposed to be belted and in the Belt tag set those points (they will change color) and choose the object they are supposed to belt to (probably the kite’s frame).
  • Mike Moon
    July 15, 2011 at 12:18 am
    nm i got it.
