Activity Forums Adobe After Effects Closing windows in AE8
  • Closing windows in AE8
    Posted by Alistair Liddell on June 30, 2008 at 4:02 pm
    in AE 6.5 and previous versions if you opened a comp in the timeline then closed it, you would be taken back to the comp you had just come from. In AE8 (and maybe AE7, I jumped from 6.5 to 8) when you close the comp it takes you to the next comp in line. Not the comp you have just come from. It only works if the comp you just came from is the next in line. I hope this makes sence!
    is there a preference somewhere I need to click or is there a shortcut?
    AL
    Alistair Liddell replied 18 years, 2 months ago 23,239 Members · 1 Reply
  • Alistair Liddell
    June 30, 2008 at 4:11 pm
    Sorry just one more thing.
    If you close the window manualy it works as it used to. It is only when you use ‘command W’ that it goes to the next comp in line
    AL
