Activity Forums VEGAS Pro Closing multiple Events
  • Closing multiple Events
    Posted by Andre Anthonio on January 21, 2011 at 6:04 pm
    If I have multiple events on a timeline, for example 30 clips with 2-3 seconds between them, how do I select that area to have the clips “collapse” or “come together” or how do I elminate the seconds between the clips, how can this be achieved in the least number of steps. Right now I’m moving each clip one by one. Embarrassing!
    Mike Kujbida replied 15 years, 8 months ago 3 Members · 2 Replies
  • Aleksey Tarasov
    January 21, 2011 at 6:20 pm
    Scripts can help you. Vegasaur toolkit has “Close gaps” commands that delete all empty slots (gaps) between selected events or on the current track. To delete gaps across multiple tracks you can use “Auditor” tool. Other scripting plug-ins (for example Vegas Pro Production Assistant) also contain similar tools.
  • Mike Kujbida
    January 22, 2011 at 12:38 am
    If you’re using Vegas Pro, here’s a script (it works in Pro 10) that you can use to do this.
    Copy it and save it as DeleteEmptySpaceBetweenEvents.js
    * Program:
    * Description: This script will Delete Empty Space Between Events In Selected Tracks
    * Author: Philip
    * Date: August 31, 2003
    import Sony.Vegas;
    import System.Windows.Forms;
    import Microsoft.Win32;
    //time intervals for split events.
    try
    // step through all selected video events:
    var FirstTrack : Track = Vegas.Project.Tracks.Item(0);
    for (var track in Vegas.Project.Tracks) {
    if( !track.Selected) continue;
    var tracktime = new Timecode(0);
    for (var evnt in track.Events) {
    evnt.AdjustStartLength(tracktime,evnt.Length,true);
    tracktime = tracktime + evnt.Length;
    catch (errorMsg)
    MessageBox.Show(errorMsg, “Error”, MessageBoxButtons.OK, MessageBoxIcon.Exclamation);
