Activity › Forums › Adobe After Effects › Closing CS6 with Render Que running/paused
  • Closing CS6 with Render Que running/paused
    Posted by Alex Bryant on October 24, 2013 at 1:47 am
    Hello,
    I have a small issue. I’m sure it’s a dumb question, but can I close AE CS6 while an object is paused in the render que and come back to it later? My current render (due to my amateur status with AE, I didn’t precomp much) is estimated at 49 hours. I need to be able to pause that, shut down the laptop, and come back to it. Is that possible?
    John Cuevas replied 12 years, 11 months ago 2 Members · 1 Reply
  • John Cuevas
    October 24, 2013 at 11:15 am
    It’s not possible. If you need to start/stop rendering, I suggest you render to an image sequence file(TIF Sequence). That way if you stop, you can look at your files(they are tagged with a frame number) and pick up from there.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
