Activity › Forums › Apple Final Cut Pro Legacy › Closed Captioning Workflow
  • Closed Captioning Workflow
    Posted by Izzy Weiss on September 3, 2009 at 10:59 pm
    Hello all,
    I’m trying to integrate FCP into my Closed Captioning workflow, and haven’t had any success…
    Essentially my goal is to
    -capture HD 23.98 material,
    -using the mastering settings in the Edit to Tape options marry the clip to an .scc file
    -Output to HDCAM SR
    I’ve tried a few times but am unable to get captions to come up. I’m looking at the Metadata on a monitor and am not seeing the CC where i typically would after adding these captions via an Ultech as i normally would…
    Additionaly, I can’t seem to capture in HD (CC) through the AJA card (or in any other way for that matter). I know AJA previosuly had some issues capturing lines outside of active video, but I though this has been fixed…
    Any thoughts would be greatly appreciated!
    Jason Livingston replied 17 years ago 4 Members · 5 Replies
  • Chris Borjis
    September 3, 2009 at 11:37 pm
    The matrox mxo2 is the only device capable of HD closed captioning as of yet.
    I heard AJA is working on something.
  • Jason Livingston
    September 3, 2009 at 11:46 pm
    Hello Izzy,
    It sounds like you’ve got a couple of workflow issues here.
    1. SCC files cannot be used for HD closed captioning because they only contain CEA-608 data, which is the analog SD captioning standard. If you try to use a .scc file when your output format is HD, FCP7 is supposed to give you a warning that the caption file is not compatible with the output format, however for some reason the warning doesn’t always appear.
    DTV broadcasts require CEA-708 closed caption data. At this time, CPC’s MacCaption software is the world’s only CEA-708 software encoder which doesn’t require a hardware caption encoder. MacCaption can import a .scc file and upconvert the data to a CEA-708 track for FCP7 and AJA KONA high definition output. MacCaption also has an Assemble Captions feature which allows you to edit previously captioned videos in FCP without having to re-caption the whole thing from scratch.
    2. Currently, FCP7 with AJA KONA only supports closed captioning in 1080i29.97 and 720p59.94 frame rates, not 24p. (Technically it is possible to put captions on native 24p video, but only very high end professional gear can display native 24p with captions. DTV broadcasts are always 720p59.94 or 1080i29.97, so you will have to telecine your 24p video to 60i/60p at some point.)
    CPC has worked with AJA and Apple to develop these workflows. We are the industry’s “go-to” people for closed captioning solutions. Please call or e-mail us, or check out our website at the link below if you’d like to learn about our solutions.
    Jason Livingston
    CPC
  • Ben Avechuco
    September 4, 2009 at 12:50 am
    It looks like you are taking an SD approach to HD captioning. It is a different beast completely.
    I am still trying to learn the process, but I ran across this the other day. I hope it helps.
    https://www.cpcweb.com/hdtv/aja_workflow.htm
  • Chris Borjis
    September 4, 2009 at 4:42 pm
    A jason, does that include the Kona-LHe ?
  • Jason Livingston
    September 5, 2009 at 2:28 am
    Hi Chris,
    Yes I’m almost certain the LHe is compatible, we’ve just been focusing on the Kona 3 and LHi first. We’ll have more info soon.
    Jason Livingston
    CPC
