Activity Forums VEGAS Pro Closed Captioning with Vegas Pro 13
  • Closed Captioning with Vegas Pro 13
    Posted by Greg Buzzell on December 29, 2015 at 6:47 pm
    I have a file that I have added a CC .scc file to. When it is added, I get blue tabs on the time line. When I click on the tabs, it shows the captioning, however it does not show up on the preview monitor even though CC1 is selected. I rendered the file out as a MXF, with captioning. I re-imported the file into Vegas, and it shows all the orange CC tabs, and shows it has captioning. However, again, captioning does not show up in the preview monitor. I ran the mxf file thru my server, and it shows there is no captioning in the file, even though Vegas says there is captioning. Any suggestions?
    Greg Buzzell replied 10 years, 8 months ago 3 Members · 4 Replies
  • Aleksey Tarasov
    December 29, 2015 at 7:08 pm
    You forgot to run script “Promote media closed captioning”
  • Greg Buzzell
    December 29, 2015 at 7:55 pm
    Ran “Promote media closed captioning”. Now the CC only shows up when I scrub the file. (On both the original and the rendered file). If I run it in real time, nothing shows up in preview. Also when I run the file thru my on air server, it also does not display CC. Does that need to be turned on when rendering the file?
  • George Dean
    December 29, 2015 at 9:23 pm
    I don’t know if this will help, but there was a closed caption bug fix in VP13 version 444.
    Best Regards…..George
  • Greg Buzzell
    January 4, 2016 at 4:37 pm
    Downloaded the update, and that fixed the CC problem within Vegas. Thanks.
