Activity Forums Blackmagic Design closed captioning with FCP 7 and Decklink SD
  • closed captioning with FCP 7 and Decklink SD
    Posted by Tiffani Sherman on October 29, 2010 at 5:30 pm
    Hi and Help!
    Is anyone using FCP 7 and an old-fashioned Blackmagic Decklink SP card able to successfully use the closed captioning option in Print to Video? If so, what settings do you use and how do you do it?
    I need to output to Beta SP. When I try to add the captioning data from the timeline, I either get an error saying my device doesn’t support closed captioning data or closed captioning data not found on the file.
    Thanks for the help!
    Tiffani Sherman replied 15 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
