Activity Forums Blackmagic Design Closed Captioning Question
  • Closed Captioning Question
    Posted by Norman Lafranchi on December 3, 2005 at 12:05 am
    I’ve been having problems outputing closed captions with decklink extreme on a PC (Premiere) using Leapfrog Ccaption.
    If I use the Analog component output, Decklink seems to cut off the “Line 21” caption area of the video. I read on a user review of CCaption that this is the case.
    I tried using the SDI output, and it doesn’t seem to cut of the line 21, but it’s still not working; if I import the CCaption Decklink AVI file and play it back to a TV, the captions don’t show up.
    Has anyone done this? If so, what is the procedure for a PC?
    Andrew Mcleod replied 20 years, 9 months ago 2 Members · 1 Reply
  • Andrew Mcleod
    December 7, 2005 at 12:38 am
    In using the Demo version of CCaption I was able to output an AVI which included close captioning.
    Demo software story about three bears etc.
    The line numbers I had enabled were 18, 19 and 20. Additionally the monitor requires the support for Close captioning to be enabled.
    If you have further issues please email pcsupport@blackmagic-design.com
    Andrew McLeod
    Blackmagic Design
