Activity Forums AJA Video Systems closed captioning problem
  • closed captioning problem
    Posted by Rick Lavon on June 5, 2010 at 12:10 pm
    Hey all- having an issue capturing an SD Beta tape complete with closed captioning encoding. We have a tape with standard closed captioning done at a dub house. We can do it just fine in 2 of our 3 edit rooms, but for some reason I can’t in the third–
    Room 1-
    Mac Pro, OS 10.4.11
    FCP 7.01
    Aja Lhi
    Control Panel 7.5(?)
    Digibeta
    Capture thru SDI uncompressed 8-bit 720×486…works fine
    Room 2-
    2005 G5, OS 10.4.11
    FCP 6.06
    Aja LH
    BVW-75
    Capture uncompressed 8-bit 720×486 YRB and composite..works fine
    Room 3-
    Mac Pro, OS 10.4.11
    FCP 7.01
    Aja Lse
    BVW-75
    Control Panel v.7
    Same settings as above
    Will not work in either YRB or composite. Will not work with DVCAM as well. Even tried looping out of monitor into Aja. I can see the encoding on the clip, it just isn’t being recognized as closed captioning. The only variable I see is an issue with is the Lse card. Any other thing I should be looking for?
    Rick
    Gary Adcock replied 16 years, 3 months ago 2 Members · 1 Reply
  • Gary Adcock
    June 7, 2010 at 2:01 pm
    [Rick Lavon] “Aja Lse
    BVW-75
    Control Panel v.7
    Same settings as above Will not work in either YRB or composite. “
    I am not sure the LSe Supports the CC protocols as that is an older product.
    You really need to call tech support to get an answer to this one.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/24640
