Activity Forums Apple Final Cut Pro Legacy Closed Captioning embedded on HD
  • Closed Captioning embedded on HD
    Posted by Dan Nethery on April 10, 2008 at 7:24 pm
    Does anyone know of any kind of software that will embedded CC on to an HD project. I’m using a kona 3 card to my HDCAM deck. We are paying another company to provide the caption file. I would prefer to do it in FCP instead of going though a box.
    thanx, dan.
    Andrew Saliga replied 17 years, 1 month ago 8 Members · 12 Replies
  • 12 Replies
  • Kevin Monahan
    April 10, 2008 at 8:00 pm
    Check out this site: https://www.cpcweb.com/
    You need maccaption or ccaption.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Dan Nethery
    April 10, 2008 at 8:09 pm
    Yeah I’ve spoke with them on the phone, they say that there product doesn’t support SDI connections. I that I’m going to have to spent a bunch of money on what ever I get. I’m just hoping for a simple solution….
  • Kevin Monahan
    April 10, 2008 at 8:12 pm
    Yes. Unfortunately, closed captioning is not an easy nor cheap thing to do.
    Kevin Monahan
  • Devin Crane
    April 10, 2008 at 9:07 pm
    They support SDI we use it all the time and have had no problems. AJA, Blackmagic do not make any of the HD-SDI Vertical Ancillary data area other than that part which contains the active video available through a software API. It’s really in AJA or Decklinks court.
  • Walter Biscardi
    April 10, 2008 at 10:49 pm
    Contact CaptionMax. We use them for all of our captioning work. Really easy folks to work with and the prices are definitely reasonable.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Andreas Kiel
    April 17, 2009 at 12:54 am
    Something which is missing here:
    There is no CC for HD defined!!!
    Except you got an Omneon Playout Server with some special software and a matching broadcast chain and some receivers which will work with this special setup.
    Andreas
    Spherico
    https://www.spherico.com/filmtools
  • Andy Mees
    April 17, 2009 at 1:55 am
    i would wait and see what the announcements from NAB bring with regards to Closed Captioning
  • Andrew Saliga
    June 18, 2009 at 6:10 pm
    Dan,
    Did you ever discover a working solution? If so, what is it. I’m about to output an HD project with CC through a Kona 3 as well.
    -Andrew Saliga
    Steelehouse Productions
    http://www.steelehouse.com
  • Dan Nethery
    June 18, 2009 at 7:01 pm
    No, I have been emailing and calling Aja for the lst year . They are like Sony… “just a few more months” and still nothing. Contact Jason at MacCap… They have an HD solution… and their cap software is the best I have ever seen. We have sent 10s of thousands of $$$ on caption gear.
  • Andrew Saliga
    June 18, 2009 at 8:17 pm
    Nice.
    I’ve heard good things about MacCaption. MacCaption allows you to output to an HD tape format?
    -Andrew Saliga
