Activity Forums Avid Media Composer Closed Captioning “Capturing”
  • Closed Captioning “Capturing”
    Posted by Craig Hirshberg on February 28, 2006 at 4:58 pm
    Kind of a 2 part, 2 forum question: 1) Is it possible to do closed captioning in Encore 1.5? 2) Is it possible to “rip” or “export” closed captioning off a Beta tape from an Avid? (The Avid captured the closed captioned info track, because it displays it if I run a composite line out to a regular TV)
    We basically want to burn a DVD in Encore and retain the closed captioning that’s on the Beta SP tape.
    Craig
    Craig Hirshberg replied 20 years, 6 months ago 2 Members · 2 Replies
  • Bill Stephan
    March 1, 2006 at 1:39 am
    I’m not sure if Encore supports closed captioning, but if it does, there will be a way to import a captioning file (.scc or .cc) into the authoring software. That is how you must implement closed captioning, as MPEG encoding pretty much destroys the caption data (although I have seen caption data survive encoding on rare occasions).
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
  • Craig Hirshberg
    March 1, 2006 at 5:13 pm
    Thanks for the reply. I was afraid the compression was the culprit here. Also, I need to upgrade to Encore 2.0, which supports closed captioning.
