Closed Captioned Quicktime File With a HD DVC Pro Codec
Hello Everyone,
I need to make a Closed Captioned Quicktime file with a HD DVC Pro Codec. I’m not having any luck using Final Cut Pro (V.7.03) with the VANC on in the Kona 3 Control Panel. Is this even possible?? If not what do I need..
Thank You In Advance,
Daniel
