Closed Caption in preview window
Posted by Roger Bansemer on October 18, 2010 at 3:57 pmClosed captioning is suppose to show up on my preview but I must be missing some setting. Anyone know what that might be?
ThanksKarlton Wu replied 15 years, 10 months ago 2 Members · 3 Replies -
Roger Bansemer
October 18, 2010 at 5:59 pmI included the snapshot in my post and to me it looks like it is toggled to be on.
Karlton Wu
October 18, 2010 at 6:26 pmIf you select “grid”, can you see grid in Preview?
If yes, then your CC markers have issues.For pop-on style caption, it should look like
{RCL}{ENM}{R14In00Wh}- HI. I’M MURRAY FROM “SESAME{R15In00Wh}STREET,” AND I’M LOOKING{EDM}{EOC}For roll-up style caption, it should look like
{RU3}{CR}{R15In00Wh}AND IT’S THE INTERNAL VALUES,In case, your CC markers are incorrect, no need to panick.
If you want pop-on style caption, the fix is pretty easy.
Save a copy of your Project just in case.
Tools->Scripting->Export Closed Captioning for DVD Architect, you get a .SUB file.
Delete all CC markers, then File->Import->Closed Captioning->
(Select File types. sub) to import the .SUB file.
You get your pop-on CC markers.If you need roll-up style caption, you have to fix it one by one.
