Closed Caption effect
Posted by Phillip Grey on April 23, 2010 at 1:07 amI’ve been given the opportunity to create a music video for Xiu Xiu. As part of the style of the video, I’d like to emulate the old television closed caption effect, where the text types up and the black lines get longer to compensate in near real time.
Is there any kind of short cut to accomplish this in Vegas or am I stuck doing it on a more frame by frame basis?
Karlton Wu replied 16 years, 5 months ago 3 Members · 9 Replies -
Karlton Wu
April 23, 2010 at 3:18 amI am not sure I understand your need. Are you talking about
Paint-On style Closed Captioning?A Paint-on Style markup will look like
{RDC}{R14In04Wh}Row 1 Text{R15In04Wh}Row 2 Text
If needed, you can insert {TH} to emulate typing delays,
like
{RDC}{R14In04Wh}R{TH}o{TH}{TH}w 1 Text{R15In04Wh}Row 2 TextYou can save it as template so you do not have to type
the markup again.RDC stands for Resume Direct Captioning.Nowadays, people use Pop-up style most.Vegas does auto
Pop-up markups if users input only texts. -
Karlton Wu
April 23, 2010 at 1:48 pmThen you are talking about Roll-up Style Closed Captioning.
Your Markup will look like:
{RU2}{CR}{R15In00Wh}{TabOff1}New Text
{RU3}{CR}{R15In00Wh}{TabOff1}New Text
{RU4}{CR}{R15In00Wh}{TabOff1}New Text
The one in your picture is {RU4}, i.e. you see three lines.
Phillip Grey
April 23, 2010 at 3:02 pmYou’ll have to forgive me; I’m not quite sure what you mean. Is this some type of script I have to write?
Mike Kujbida
April 23, 2010 at 3:36 pmPhilip, Karlton is referring to doing actual closed captioning but what I think you’re looking for is an FX to allow you to recreate that look.
The short answer is no, you can’t do that in Vegas.
You’ll need to recreate it in an app like Photoshop, use Pan/Crop or Track Motion to move it up the screen and use the cookie cutter to limit it’s upward visibility. -
Phillip Grey
April 23, 2010 at 3:40 pmIn that case, how do you do actual closed captioning? My plan is to take some video (with closed captioning) and then shoot it off the TV so if there’s a way to make closed captioning that would work, as well.
I’ve been experimenting with the cookie cutter method in the meantime. For the most part, it does the job but it’s painstaking and not 100% satisfactory. Thank you.
Mike Kujbida
April 23, 2010 at 4:07 pm“In that case, how do you do actual closed captioning?”
The latest update to Vegas Pro 9 added this feature and that’s what Karlton was referring to.
I’ve done subtitles in DVDA but never real closed captioning.“I’ve been experimenting with the cookie cutter method in the meantime. For the most part, it does the job but it’s painstaking and not 100% satisfactory.”
If you don’t mind a small black bar going all the way across the screen instead of stopping at the end of each line, then you could do it very easily in Vegas.
Phillip Grey
April 23, 2010 at 7:54 pmAlright, I updated to 9.0D and I see that command feature now but I still can’t get it to work.
I chose:
Command: WMClosedCaption*
Parameter: {RU4}{CR}{R15In00Wh}{TabOff1}New TextI rendered this and watched it in Windows Media Player with the Captions and Subtitles option turned on but to no avail.
*I also tried the TEXT command.
Karlton Wu
April 24, 2010 at 3:47 amNot that one, try 608CC1. A kind reminder: 9.0d supports
Closed Captioning only for HD XDCAM MXF.
