Activity › Forums › Apple Final Cut Pro › Closed Caption added with Compressor not showing up
Posted by Chad Greene on October 4, 2016 at 9:35 pmI didn’t see a Compressor forum so I decided this was the next best option. Hopefully you guys can help me.
I cut a 30 minute TV special in FCPX and have been delivering it to stations with a Closed Caption sidecar (separate file). Most stations are happy with that… except for one. They asked me to embed the CC into a MPEG2 file. I did this via Compressor, but when I try to view it back, the CC info does not seem to be there. Any ideas what I need to change? How do you guys add closed caption to masters?
Chad Greene : Mahoney Media : Minneapolis, Minnesota : 2×2.66 GHz 6-Core Intel Xeon, 12GB Ram, OS 10.11 FCPX, Kona-LHi
Chad Greene replied 9 years, 11 months ago 4 Members · 8 Replies -
Noah Kadner
October 4, 2016 at 10:39 pm -
Andreas Kiel
October 4, 2016 at 10:56 pmThis workflow won’t embed the captions into the MPEG signal. It will just add it like a side car file.
You will need a Telestream app. PPro might be an option as well, but there are many reports about not working results.
An external service provider probably is the best way to go.– Andreas
Spherico
https://www.spherico.com/filmtools“He who fights with monsters should be careful lest he thereby
become a monster. And if thou gaze long into an abyss, the abyss will
also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil -
Chad Greene
October 5, 2016 at 3:06 pmNoah, yes using that workflow.
Andreas, your comments match my experience that Compressor won’t embed the captions. It seems to only let me view the sidecar file. However, I find that odd because the 3PlayMedia workflow AND the Apple help files make it sound like it will work. In fact I see multiple websites showing compressor as being a good option (another example).
I have Telestream Episode. Have you had luck embedding closed caption with that?
Andreas Kiel
October 5, 2016 at 3:58 pmHello Chad,
Yes it’s odd that Apple and 3PlayMedia describe that workflow as recommend.
In some cases it is working in other cases it’s not working – it depends on the broadcaster.Technically Apple solutions cannot interleave subtitle informations into the MPEG2 stream. Some people would they can, but as I worked with/and for HPA (the company Apple bought for their MXF/MPEG solutions)I know that the Apple solution only supports Audio/Video.
I’m no sure whether Episode would supply a “real” caption-audio-video solution. For what I know you need MacCaption.
Regards
AndreasSpherico
Chad Greene
October 5, 2016 at 5:34 pmThanks for the knowledge. I am now leaning toward paying to have the file made. Are their any companies you recommend?
Francois Jean
October 5, 2016 at 5:41 pmThis software could work for you when Compressor can not do the job …
https://itunes.apple.com/us/app/switch-3/id1088508263?mt=12
FRANCOIS
Andreas Kiel
October 5, 2016 at 6:01 pmI forgot Switch. I haven’t tried it, but it would be worth to try – seems there is a demo available.
Unfortunately I can’t help with a company recommendation since I’m in Europe and those I know here normally don’t work with US CEA-60X.
– Andreas
Spherico
Chad Greene
October 5, 2016 at 6:50 pmFrancois thanks for the idea. I downloaded the free version which plays my master just fine, but to check the CC I have to upgrade which is not worth it. It seems to only be a viewer.
So I will have to call a company in the USA to help me.
